srschang
Dec 12, 2020Nomad
Kayteg1 wrote:
I doubt SRW and DRW have the same springs?
That beside the fact that the number you posted might be result of taxation and have loose connection with actual axle capacities.
SRW usually are sold with GVW below 10k lb, when DRW below 15k lb.
That is due that in most of the states rating it above those numbers might bring commercial requirements, different smog requirements and definitely higher fees.
My F450 had sticker for 15k lb, where set of tires added to 22k lb and I actually used it above 20k lb.
I only have one data point, but my 2020 Ram 3500 SRW has a GVW of 12,300 lb.
44,071 PostsLatest Activity: Aug 30, 2026
