Bedlam
Dec 14, 2020Moderator
ticki2 wrote:jerryleejr wrote:
I understand there’s a lot of variables but let’s say a Ram 3500 chassis cab comes in both SRW and DRW configurations. The SRW lists 6800 RAWR and 9850 for the DRW. That’s why I’m assuming it’s the tires...
JJ
Usually the differences are tires , wheels and springs . Axles are the same .
The DRW are typically heavier than SRW axles in the current trucks. If you look at the OEM ratings from Dama or AAM, they typically have at least 1k lbs more capacity with larger tubes or ring gears.
44,071 PostsLatest Activity: Aug 30, 2026
