ticki2
Dec 14, 2020Explorer
Bedlam wrote:ticki2 wrote:jerryleejr wrote:
I understand there’s a lot of variables but let’s say a Ram 3500 chassis cab comes in both SRW and DRW configurations. The SRW lists 6800 RAWR and 9850 for the DRW. That’s why I’m assuming it’s the tires...
JJ
Usually the differences are tires , wheels and springs . Axles are the same .
The DRW are typically heavier than SRW axles in the current trucks. If you look at the OEM ratings from Dama or AAM, they typically have at least 1k lbs more capacity with larger tubes or ring gears.
I have looked for the newer ratings on the AAM axles but have not found any . If you have them would you post .
44,071 PostsLatest Activity: Aug 30, 2026
