Mickeyfan0805
Jan 05, 2021Explorer
mbloof wrote:
Historically these arguments follow four general themes:
First one is that the numbers on the door sticker are legally binding. Sub arguments on this theme follow ether the payload or GVWR and delve into DOT, State or local level rules (laws?) that have law enforcement writing tickets for non-compliance. Some go so far as ether having roadblocks with portable weigh stations or LEO's carrying scales with them.
Since just about every car+truck has to have the sticker, there has to be some reason for it right?
Second one is in the case of a accident anyone that is over ether GVWR or payload numbers is more at fault or instantly at fault making the person with the 'over weight' rig liable for everything. Added bonus is that the LEO's carry scales with them (or simply haul them) to accident scenes (or repair shops) and anyone "over weight" is at fault.
Third is that you better check the fine print of your insurance documentation as your insurance company is going to deny coverage if you are "over weight". Again here if the first two don't get you, your insurance company (or the OTHER company(s) will) have someone weigh your rig and if your "over weight" your screwed.
Last but not least forth theme is that you will get sued and loose everything because you are "over weight" of the values on the door sticker. (and were involved in a accident)
I've seen and heard of all of the above arguments over the years and recently in other forums. Over the years I've seen many in this forum.
At last I checked, nobody has ever passed on first hand knowledge and experience with any of them actually happening to them.
- Mark0.
Well summarized - and I would concur that this has been the general outline of these conversations.
Interestingly, while the LEO weighing issue is a plausible possibility (although one I've not encountered), the liability/insurance issues honestly seem as though they'd be harder to enforce. Any accident severe enough to bring up investigations of liability and coverage based on weight will have done enough damage to your vehicle(s) that replicating the weight accurately would be nearly impossible. WD hitch setup, gear location, fluid levels, seating positions... all of these impact the actual weight on the various axles. If a match is clearly overweight by hundreds of pounds, I could see this plausibly coming into play (although, again, I've never seen a reliable first-hand report). For those who are over by 50-100 pounds, or so, it would be nearly impossible for anyone to 'prove' you were overweight at the time of the accident.
44,071 PostsLatest Activity: Aug 30, 2026
