gbsteph
Feb 09, 2020Explorer
There are many truck camper manufacturers that have generators. My new Host Cascade has a built in Cummins propane generator. My first one with a genset. I agree with many, they can be loud and annoying to others and solar can definitely keep you charged. But on some occasions where you are out in the boonies on your own and the noise doesn't bother anyone, then they are advantageous. And depending on the climate you camp in, you may not need it all the time. Some TC manufacturers make campers with a compartment designed for an onboard generator, and/or large enough to carry a portable generator. You can opt out of the factory gen option and buy a small Honda generator and only carry it when you need it. Saving weight and having added storage. In both cases, neither may run the AC and Micro at the same time, meaning you turn off one while using the other. Hope this helps
