Ok I want to match a Truck Camper to my 2013 F250 6.7 diesel with 8' bed. There is a sticker on the door that states tire specs and max payload of 2365#s. Am I to assume that is the max load for the ...
The air bags will not do it for you. You need adfitional spring rate to carry that weight and not just leveling. The anti-sway bar I referenced is bolted to your axle and frame to reduce body roll of your truck - This is different than the hitch anti-sway for your trailer.
