Ok I want to match a Truck Camper to my 2013 F250 6.7 diesel with 8' bed. There is a sticker on the door that states tire specs and max payload of 2365#s. Am I to assume that is the max load for the ...
You have to remember these air bags are supplemental suspension and not primary. This makes them good for leveling out sag but your spring pack needs to do most of the work. This is much more noticeable when carrying a truck camper since you are carrying a lot of weight much higher than you would if it was a fifth wheel or travel trailer.
