Me_Again
Aug 26, 2018Explorer III
JIMNLIN wrote:
A 5000 lbs gross weight TT and 35' TT doesn't go in the same sentence. You have a decision to make on actual trailer weight and what size truck is needed to pull the beast.
Our new Wa/Az commuter Laredo 225MK has a 8K GVWR and a little under 6K dry weight. So do not think that shorter means lighter in all cases.
As someone stated the Ecoboost F150 with the correctly order opions is your only 6 cylinder option. Chris
