JIMNLIN
Aug 27, 2018Explorer III
Me Again wrote:JIMNLIN wrote:
A 5000 lbs gross weight TT and 35' TT doesn't go in the same sentence. You have a decision to make on actual trailer weight and what size truck is needed to pull the beast.
Our new Wa/Az commuter Laredo 225MK has a 8K GVWR and a little under 6K dry weight. So do not think that shorter means lighter in all cases.
As someone stated the Ecoboost F150 with the correctly order opions is your only 6 cylinder option. Chris
Re read what I said.
Your 8k gvwr 27' trailer doesn't qualify for a 5k lb gross trailer requirement nor is it 35' long.
So I'll stick with "A 5000 lbs gross weight TT and 35' TT doesn't go in the same sentence."
