bkenobi
Dec 01, 2017Explorer
Truck remote start and TC battery charging
When I got my TC, I had the dealership install the wiring for TC hookup under the bed. I added remote start as a feature to the truck when I bought it specifically so I could charge the batteries without having to go outside or leave my key in while idling.
I found out after using this setup for a while that the truck only provides 12v under remote start though. After speaking to the service guys who installed the wiring, it sounds like the reason is based on how they determine when to allow higher current draw. They trigger the key in ignition as the test to determine if the TC should get higher current.
Does anyone have their truck setup for charging with remote srart? I'm wondering what you trigger off of. I think the dealership will fix it for me if I explain what I need. Also, any downsides to setting it up this way I nay not be considering?
Fwiw, I have a 2016 Ram Cummins.
