Terryallan wrote:
As to As tight as you can get them. How are you going about pulling them up? If you are not using the tongue jack to raise the TT while pulling the bars. They are not tight at all. You can actually raise the rear of the TV higher than it is unhooked. You don't want that though. that IS too tight.
IF you use the tongue jack to raise the TT, AND the TV. That will remove any pressure on the weight bars, and makes them super easy to hook in any link you chose.
+1 on that... I do the same thing and it makes a big difference. I do notice my rear being a bit soft when going over dips.. I add a few pounds in my airbags to stiffen up the rear... It's level without the bags, though.
