mkirsch
May 14, 2020Nomad II
While I agree that something is wrong, I am not sure what having your brakes "checked" is going to do. The typical mechanic brake check is a simple visual inspection... "Yup, it's got brakes."
All it will serve to do is verify that there is nothing OBVIOUSLY wrong such as a burned up brake pad, or a leaking caliper, which you can do yourself without even removing the wheels.
Does it pull under normal braking? Take it out on an empty stretch of road and induce a few "Jesus take the wheel" moments. Maybe you've been subconsciously holding the wheel against a pull during braking right along?
