Grit_dog
May 14, 2020Navigator III
So truck "was" wandering (too little caster likely) and eating the outside edges ( too much toe in likely, but helps offset the wandering of not enough caster).
Truck has since had an alignment and tires, still nothing to do with brakes "pulling" per se. Since incident, which presumably was not just "yesterday", based on your subsequent post, brakes have worked fine?
Trying to understand.
But if what I said above is correct, you do not have a brake problem.
Brake problems don't correct themselves.
Also, since you didn't answer my original question...relating to the brakes, will presume the brakes have been fine ever since.
