rbpru wrote:
If you are trying to say that LTs are tested to run faster, are stronger, give greater traction and can be purchased in more load ranges than ST tire, no one is debating that.
If that is your reason for assuming they are better for TT use; then by all means buy them.
If you want to buy a tire designed and built specifically for trailer use by the tire makers, then you are looking at STs.
There is nothing mystical here.
I totally agree!
I will only use what is recommended by tire manufacturers, not something that is supposed hearsay on a forum.
If LT tires are supposed to be better and safer on trailers, then all tire manufacturers and tire sellers would be recommending them instead of recommending "cheap/inferior" ST tires.
