TNGW1500SE
Nov 24, 2014Explorer
YamaDooed wrote:
More than likely you had arcing in the plug... Clean and inspect both contacts add a lil dielectric grease and replace if they're bad...
Dielectric Grease is not supposed to be used between the contacts. Is is used to "cover" the contacts after they are put together. Electricity will not flow through the grease. Dielectric grease prevents corrosion when applied directly to metal connectors and though it works well for this purpose, it can sometimes cause a connection to stop working if not all of the grease is pushed out of the way between the points of contact inside the connector.
