River_Hill's avatar
River_Hill
Truck Wheel Size
Looking at some new trucks and have the option of 17", 18" or 20" wheels. Any reason to go with one over the other? I think the 17" might do a little better off-road as the tire would have more flex.
  • 20 inch replacements are much more expensive if you can find what you want in the first place. I don't know if there are more 17 or 18 tire types but there are plenty of 18 inch tires by lots of manufacturers and you get better load ratings. I don't even recall if 17 was an option with a HD truck. With a pickup it's a different story.
  • You will have more tire size and load range choices with 17" including AS/AT and MT type tires. The wifes 2016 1500 chevy with 17" wheels has any size and tread type available.
    I see 1/2 ton owners with the 20" options can't find a good LT replacement other than a high price LT E.
    Now if you have a 3/4 or one ton truck the 17" tire sizes don't have the capacity for a 7000 lb rear axle unlike 18" and 20" tire sizes.
    There are more 18" tire sizes/load ranges than 20" tires.
    Check out 17"/18"/20" tire prices on tirerack.com
  • 17 inch tires and rims generally have the lowest load rating. Go with an 18 if you are concerned about airing down while still having a safe load rating.
  • I agree the 17" would be better off-road . The 20" should build up less heat in the sidewalls at interstate highway speed.
