- fla-gypsyExplorer
MitchF150 wrote:
My guess is that the #7500 is the trailers GVWR.
Mitch
X2 due to the tire size listed. 205x75x15C. No way 7500 lbs is dry weight, has to be GVWR - TerryallanExplorer IIYes you can weigh it and know how heavy it is. but you still won't know if it is overloaded or how much more you can put in it.
Maybe you could google your TT, and find the GVWR. - KD4UPLExplorerMost quarries around here will let you loose there scale for free. You could also try a scrap yard.
- Cantdrive55Explorer IINever thought of that. Great idea!
- Francesca_KnowlExplorerI've weighed my rig for nothing several times- once at a grain truck scale that the farm co-op leaves turned on 24/7 and once at the landfill. And I don't know about your neck of the woods, but in mine, highway scales are also left turned on 24/7, so one can run through there when they're closed.
You don't get a certified weight ticket or anything of course, but if you just want to know the weight who cares? - MitchF150Explorer IIIMy guess is that the #7500 is the trailers GVWR.
Mitch - therinkExplorer
therink wrote:
A scale fee is abt $10. Have the tow vehicle and trailer loaded as of camping and weigh it. This is the only true weight that means anything. - therinkExplorerA scale fee is abt $10. Heave the tow vehicle and trailer loaded as of camping and weigh it. This is the only true weight that means anything.
- Cantdrive55Explorer III saw the 3400 kgs and thought the same.. 7500 pounds. I hope it's gross weight. Really don't want to run through a scale although I think it may be my only option. No other stickers inside the tt anywhere.
- Francesca_KnowlExplorer"Dry weight" is really irrelevant, as others have pointed out. You need to know the actual loaded weight as determined at a scale.
That said:
I see a number next-to-last at the very bottom of your pic that looks to me to be "dry weight", only expressed in kilograms. 3402 kilograms is 7500 pounds. Which is what I THINK the number immediately to the left says.
Thing is, though- if it means unloaded or dry, that weight seems high for the load range C tires also indicated on the label. So the above number could be GVWR (gross vehicle weight rating), which would be the maximum allowable weight for the loaded unit.
44,026 PostsLatest Activity: Jan 09, 2021
