Francesca_Knowl
Oct 08, 2014Explorer
"Dry weight" is really irrelevant, as others have pointed out. You need to know the actual loaded weight as determined at a scale.
That said:
I see a number next-to-last at the very bottom of your pic that looks to me to be "dry weight", only expressed in kilograms. 3402 kilograms is 7500 pounds. Which is what I THINK the number immediately to the left says.
Thing is, though- if it means unloaded or dry, that weight seems high for the load range C tires also indicated on the label. So the above number could be GVWR (gross vehicle weight rating), which would be the maximum allowable weight for the loaded unit.
44,068 PostsLatest Activity: Jun 21, 2026
