davehultin
Sep 11, 2023Explorer III
Trying to find a replacement window: 8505-2 (maybe?)
I've been trying to find a replacement window for our trailer with very limited luck. My preference is to be able to find an exact replacement so I can use the same screw holes, but a "close enough" replacement is OK too. I found a label hiding under the valance, here are all the different codes on the label:
B50199
2438721
10/09/17 RING-2
8505-2; 30.0x22.0; BLK
RPO QTY 60
From my searching it appears the 8505-2 code is what gets me closest to a match, but the dimensions, 30.0x22.0, would be pretty important too (of course!).
I've found a number of exit windows, but I don't need an exit window. I'd prefer something that would give me a little more control over how much the window is open (or not open). The only non-exit window I've found so far is this one:
https://www.ebay.com/itm/266295582241
It would work, I guess, but the latch mechanism seems kinda hokey to me. (You can see it in the second photo, near the top on the edges.)
Any ideas on where to get an exact replacement, or a pretty darned close replacement?
B50199
2438721
10/09/17 RING-2
RPO QTY 60
