Acdii's avatar
Acdii
TT Bike rack for truck with topper
Since my bumper on the trailer is not conducive for supporting anything other than itself and is not built in a way that it can be properly reinforced, I am looking for one that can attach between truck and trailer.
Since I have a topper on my truck that I will not remove(I store the genny and tools there) I am looking for one that won't interfere with the topper.
Max would be 4 bikes. Mountain bikes if that matters.
  • Acdii wrote:
    bob2194 wrote:
    the other possibility, they sell front mounted hitch receivers. You could put one of those on the front of your vehicle and you would not have a turning radius problem and you could put on any receiver mounted bike mount you wanted.
    Wont work with the Ecoboost, It was actually the first thing that came to mind.
    Could you tell us why it won't work?
  • OTOH came across this on Amazon which is rated at 500 lb/ft of torque which should have no issues supporting 4 bikes. Then I could go with any 2" tube bike carrier.
    I had installed a 2" clamp on receiver, and never used is after finding it crushed the bumper tube a little too easily, which would eventually cause it to crack if I used any brackets to support the bumper, hence why I was looking for a front mount. Not at all concerned about tail weight as it is actually a tad nose heavy @ 13.8% on the ball.
  • the other possibility, they sell front mounted hitch receivers. You could put one of those on the front of your vehicle and you would not have a turning radius problem and you could put on any receiver mounted bike mount you wanted.
  • Thanks, I saw that one, but only holds two bikes. My main concern is turning room. I did see there is a clamp on one that clamps to the 2" shank and straps to the tailgate to secure it from swaying. It holds 4 bikes, but turning looked tight which means backing up would be a pain and would have to be removed.
  • If you have sufficient space on the tongue (4 inches or so) build one. Mine works great. “Mountain bikes” doesn’t help since they range from 25 pounds to 40. Times four could mean 160 plus the rack. Sufficient TV payload?
