AndrewM wrote:
Terry, let me make sure I understand GVWR correctly. GVWR is maximum total weight of vehicle, cargo, people, fuel, and other fluids together. Correct? So if I take my truck to the scale, I'll get a weight of each axle. As long as those axle weights do not exceed their ratings and the combined weights don't exceed the GVWR, I'm ok.
If I weight the truck with the WDH disconnected, I'll see a very large increase in rear axle weight, and a decrease in front axle weight. With the WDH connected, a much lower weight will be added to the rear axle and weight will now be added to the front axle as well. The combined axle weights with the WDH connected will be less that with the hitch disconnected. That difference is what gets distributed to the trailer. Why should that weight still be factored into the GVW calculation? It is not on the truck anymore.
It's still on the hitch. Is it not? Isn't that why there is a WDH max hitch capacity?
The hitch is carrying / handling / moving all the weight, and the hitch is installed in the receiver. I agree some weight is transferred. But 600 lbs of tongue weight is 600 lb of tongue weight, and it is all on the hitch / receiver, In one way or another.
I may be wrong. But I'm pretty sure. The tongue weight still has to be counted on the TV. As the hitch / receiver, transforms the frame of the TV in to the lever that transfers the weight. Ain't that right? After all. IF the frame is too weak. No weight will be transferred. It will just bend. Just as several years ago, GM receivers were too weak to properly transfer weight. they bent instead.
