More to think about:
One of the new fiberglass sided TTs with light grey or tan color, swooping graphics and a pronounced curved front cap look pretty sexy. Add frameless windows and they look even sexier. However, beauty is only skin deep.
A fiberglass sided TT superstructure is very rigid due to it's aluminum framing and composite sandwich construction. As any owner knows, trailers bounce like heck travelling down roads. The vertical movement in the I-beams of the main frame is worse in some if they have one of the weaker frame designs (I-beams made from 3 pieces of steel welded together). Even strong frames flex up & down somewhat.
All the vertical movement in the I-beams gets transferred to the superstructure above and in a rigid aluminum-framed one, can cause welded joints to fail. Reason I know is that it happened to a previous TT we owned as shown in this photo. It only had literally a few thousand miles and most were from the delivery from Indiana to the west coast. I accidentally came across this while doing a mod inside the pass-through compartment. Could have been more failed welds, will never know as it went back to the dealer.
A TT with wood framing will have a lot more give in all the joints/connections and would probably be a better choice for someone planning to do back country camping on rough roads. I think it's Outdoors RV that have aluminum framed walls but use wood trusses?
What I don't like about fiberglass or metal siding is that the impervious vapor barrier layer of the "wall assembly" is on the outside. That's opposite to how houses get built. Moisture laden air will migrate to the exterior skin and condense on the interior side of it leading to rot and corrosion or delamination. Composite walls use open cell insulation which lets moisture through it and closed cell foam would stop moisture issues but of course, costs more. Camping in the winter without properly and adequately venting the moisture outside, or using a dehumidifier, can cause some serious damage in the long run and one type of siding may not be better than the other. TT manufacturers do a cr*p job on insulating, including the ceilings.
Have owned a TT with both types of siding. From a structural perspective, I'd go wood framing/aluminum siding. For looks and easier washing/waxing, a fiberglass sided unit. Regardless, gotta make sure to prevent leaks and water intrusion or else it won't matter...
![](https://i.imgur.com/hSY9FOjm.jpg)
