kadylady
Mar 05, 2019Explorer
TT Roof Leak
We have a 2003 Keystone Springdale 27'. After the last snow we discovered water was leaking from the seam on roof near front, where the rubber (?) roof meets the aluminum. It's the only seam on the ...
wanderingaimlessly wrote:
You will probably get a much better price on sealing and coating from an independent than a dealer.
If you want to reseal, have the seams and edges all cleaned and recaulked, you may want to have eternabond applied around the edge and around all openings, then you can have the entire roof recoated with a product like Hengs rubber roof coating.
Is this what the dealer you were talking to was going to do? Or were they simply going to roll a coating?
