boosTT's avatar
boosTT
TT Tipup Risk
My TT is about 4500 Lbs, 22' and tandem axle.
When unhitched and without the stabilizer jacks down: how much weight is required behind the rear axle to lift the tounge? When I had a popup this was a valid concern... it was quite easy to accidently lift the front of the camper with weight applied behind the rear axle. Is this not an issue with tandem axle trailers?
  • Probably not an issue, unless you have a lot of beef in the back. 4500 lbs trailer should have about 540 lbs of tongue weight, which is significantly more than your pop up.
