- esjayExplorerWas the 4.7 the only iron block Toyota V8? I seem to remember that when the first gen Tundra came out, Toyota decided to give it an iron block engine for "perceived" durability by the typical pickup buyer. That's probably the reason it was replaced by the alum. 4.6 as now aluminum blocks are pretty much the rule.
- otrfunExplorer II
esjay wrote:
I can't speak for the Lexus engines; however, the 2007-2009 Tundras with the 4.7 engine have the camshafts driven by a belt (similar to a typical serpentine belt). Toyota recomends they be replaced every x amount of miles. Toyota replaced the 4.7 engine with the 4.6 in 2010. The camshafts on the 2010-2013 4.6 Tundras are chain driven (internally lubricated by the same oil that lubricates the engine). Under normal operating conditions they will never need replacing.
400,430,460 Lexus cars take a belt. It's not as expensive as some shops would like you to believe. A good mechanic can change one out in two hours. The timing belt makes for a very smooth, quiet engine. All of the Lexus cars have alum. block and heads.
You guys have me confused as to whether the 460 and 470 trucks take a belt or not. - W_E_BGoodExplorerThe 4.6 L V-8 is an aluminum block derived from the Lexus enigines, but has a chain, not belt.
pickuptrucks.com - TECMikeExplorerBelieve Tundras are now built in San Antonio, Texas now. While I am a Ford guy, I will be the first to say our friends's older 4.7 Tundra has been a wonderful, trouble free, tow vehicle.
Nothing done except oil, filter, and regularly scheduled maintenance. Believe they have close to 80K miles, most of which have been road miles towing their Casitas.
They put on a new set of Michelin tires a couple of years ago that made the ride and towing experience even better, they said. - esjayExplorer400,430,460 Lexus cars take a belt. It's not as expensive as some shops would like you to believe. A good mechanic can change one out in two hours. The timing belt makes for a very smooth, quiet engine. All of the Lexus cars have alum. block and heads.
You guys have me confused as to whether the 460 and 470 trucks take a belt or not. - Ron3rdExplorer III
skyhammer wrote:
esjay wrote:
spoon059:
Well, that shows what I know, or don't know. I'm very familiar with the 4.6 if it is the same one that Lexus uses. I was told wrong by Toyota salesmen about the towing package if this is true.
However, 2mpg difference almost makes this a nonissue, especially since the 4.6 requires timing belt replacements. It is one very smooth and refined engine though, so I may reconsider it. Toyota has one of the most confusing websites when it comes to building a vehicle. I'll probably buy a Tundra, then two weeks later discover that a diesel Tundra is on the way soon. Yes, I have read the rumors.
The 4.6 Toyota engine does not have a timing belt, it has a chain like the 5.7.
I think you're correct. The old 4.7 V8 used in the first generation Tundras used a belt. That motor was originally designed for the Lexus line of cars and used in the Tundra too. Very bulletproof motor but glad I did not have to replace the belt in my old 2000 Tundra which I heard was pricey! - otrfunExplorer II
skyhammer wrote:
I've heard this before. I'll say this: my friend's 2010 Tundra 4.6 has brown-reddish rust all over his block (heads are aluminum). My 5.7 has that typical silver powdered corrosion on the block & heads.
The 4.6 has an aluminum block, just like the5.7. - skyhammerExplorerWhile it is true that currently the CM limited is not available with the 4.6, it was available when the 4.6 first came out.
You could always get any model CM, DC,Reg Cab, with the 4.7.(07,08). - skyhammerExplorerThe 4.6 has an aluminum block, just like the5.7.
- esjayExplorer
skyhammer wrote:
\esjay wrote:
spoon059:
4.6 is not available in the Crew Max Limited. We have to have power heated buckets, thus a Limited with the 5.7.
44,068 PostsLatest Activity: Jun 17, 2026
