greddy09sc's avatar
greddy09sc
Tundra Crewmax shortbed pull a 5th wheel?
I have a 2015 Tundra 5.7L V8 Tundra Crewmax. I'm looking to buy a 5th wheel. I purchased a used 5th wheel hitch with air bags already. Just need to get it install.
I've been having mixed reviews and been told that I can and cannot pull a 5th wheel. Not due to engine size but because of my 5 1/2 feet shortbed.
1. I have a shortbed due to the 4 door crewmax. If I turn with a 5th wheel, then it will hit back of my cabin.
2. You can install an extender on the 5th wheel.
3. You need a slider.
Anybody here with a Tundra crewmax pulling a fifth wheel? I've seen many pictures of a double cabs but not crewmax full four doors.
Currenlty looking at a 29ft 2006 Wildcat.
  • Have you looked at the pin weight on that 5er? NADA list the GVWR as around 8000 lbs which is light, but on most 5er's the pinweight is around 20%, which would be about 1200 lbs empty. Your truck I think has roughly 1500 payload so by the time you get in the truck, and add a hitch setup with it otherwise empty your right up at the payload capacity.
    The truck will pull it, but she will likely be over the payload limit.
