Lessmore's avatar
Lessmore
Explorer II
Oct 28, 2014
Turbo small displacement - displacement on demand- a winner?
Boy Ford's new 2.7 liter turbo truck engine....375 HP out of 2.7 liters(Correction....325 HP -** Thanks Fast Mopar.).....that's about 168 cubic inches. I did the conversion in my head....so that's just an approximate...I'm sure I'm out a few cubes ...+/-.
The correct cubic inches is 168.** Thanks ib516,
That's an awful lot of power being squeezed out of a relatively tiny engine....in a heavy truck that has a significant payload and towing capacity.
I think somewhere there has to be a balance...between cubic capacity....HP/torque being produced...purpose of the HP/torque.....general durability and long term longevity of certain high stress components. In this case the...high rpm, bearing cooling, capacity of the turbocharger(s).
I'm not a mechanical engineer and I'm sure Ford would have these questions resolved, before production.
But they are things that I would have in the back of my mind, if I owned a 2.7 turbo engine in a truck.
Another question is how low....cubic inch capacity....truck duty....will Ford go ?
They started with the 3.5 turbo V6 in the F 150. Now a 2.7 liter turbo V6 in an F 150 and this 2.7 puts out more HP/Torque than the original 3.5 Truck turbo V6.
How small an engine can Ford go to, in a full sized truck, with full size cargo/tow ratings ?
Where is the bottom line...for cubic inches ?
I'm not being critical, just inquiring.
GM seems to be going with larger cubic capacity, more cylinders...ie; 5.3 liter regularly aspirated (no turbo forced induction)... but with displacement on demand with 6 to 8 cylinders....than cutting out 2 to 4 cylinders under light load.
Which is better ?
Both Ford and GM are looking at the same way of achieving efficiency / improved fuel economy, while maintaining very good HP/Torque output. Same way being with reduced displacement....either permanent (fixed engine capacity, but forced induction- Ford) or varying displacement (displacement on demand, non forced induction- GM).
As with most things, eventually and probably....only one technology will win out.
Which will it be and why ?
  • 2.7 eco boost is 16.6/21.5/18.5
    5.3 is 13/19/15.2 This is a steel bodied truck
    3.5 Eco is 15/21/17 I believe this is a steel body figure.
    3.7 ford gas is 16/21/18 I believe this and 3.5 eco numbers are with steel body last years model.
    Ram Eco diesel is 18.6/25.8/21.2
    It seems that the 3.5 eco boost might be the sweet spot for Power vs. economy. It takes a precise amount of fuel to make HP. It may be that at 3.5 liter you start to find much smaller gain by reducing cubic inches. When both engines are in the same truck at the same weight.
