Terryallan wrote:
HikeN2Mts wrote:
Just a question when I'm towing on mountains roads uphill I slow down of course gas engine, just wondering when I drop to around 40 or less would it help to turn on the 4 wheel drive in high mode to have the front wheels help pull?
4WD will NOT give you more power. It only gives more traction. You will be going the same speed, Just burning up the transmission as well.
To build on this post, lets say you have for example a 300 HP (at the crank) engine. Chances are, you're probably putting about 240 of thoses horses down to the bitumen due to "parasitic losses". This is energy burned due to friction in the transmission, drivetrain, churning of oils and other little things that sap horsepower. If you turned on 4WD, you'd add even more parasitic loss (you now have another differential you're spinning and putting power to) which means you're probably only putting something like 230 or less horsepower to the ground. So you've basically slowed yourself down even more.
This is neglecting what the additional stress of 4wd in the dry does, basically tearing upart or adding heavy wear to the gears and chain drive due to not having a "Slippery" surface to allow the axles to differentiate in speed a little bit.
Simple 4wd explanation here:
Engineering explained - 4WD
