Resoman
Sep 04, 2015Explorer
Turn signal problem...
jOne of the turn signals on my newly acquired 2013 Rockwood pop-up doesn't work. The running light is fine but the brake and turn signal don't do anything. The two filaments in the bulb looked fine, but I hoped a new bulb would solve the problem; it didn't.
I noticed one thing that surprised me: both the new and the old bulb will only fit in the socket one way. That is, the socket won't accept the bulb after rotating it180 degrees. The bulb is the kind with two filaments and two terminals on the base, with a regular bayonet mount.
The base of the socket is spring loaded and seems to press up against the bulb well enough.
Could the problem be with the newly installed brake controller and connector on my tow vehicle? It's a 2011 Toyota Sienna.
Thanks in advance for any ideas!
Gary
Gary
