dl68camper wrote:
2012Coleman wrote:
Lots of people use the idea Westend mentions. You can also use a stud finde to fint the stud and mount the bracket. I used small lag screws. I also have a 23" flatscreen that travels well while mounted. Whatever you do, don't mount anything using pop rivets.
I don't know what to make of your suggestions. Stud finder is pretty much useless in a camper with plywood walls and fiberglass exterior and I've used pop rivits hundreds of times. Camper manufacturers use them all the time. I don't know yet if they would work in this application and yes it would be ideal to drive lags into studs but finding them could be difficult and I'm unsure of the thickness in both locations.
I've used a stud finder to locate the aluminum tubing in the side walls of my camper several times, both inside and out. Personally, I wouldn't rely on pop rivets to hold up a TV. I would use a backer board at least 3/4" on an inside hollow wall, spanning the distance between 2 studs. Our TV is mounted on an outside wall, with a 3/4" oak plywood panel screwed into the aluminum tubing, and the mount is screwed to the plywood. With the edges veneered and a matching finish, it all fits in like it was original.
