Saulman wrote:
I have the same unit. I bought a 32" tv to install in the designated place. It was too big ! You could not open the cabinet doors without removing the tv. I ended up buying a 24" tv and its almost too large. There must be plywood behind the paneling because my lag screws were going in something thick. It hangs there just fine and is plenty large enough for viewing for the bed. We love our Reflection. Our last camper had storage in the rear and we could not keep tires on it. Too much leverage putting too much weight on the axles. This one tows much easier and does not sway at all.
I agree on the easy towing. I had the dealer put an Equalizer 1400/14,000 lb. hitch on it and I pull it with a 2016 Silverado 2500 / Duramax engine. It pulls like a dream and the truck rides amazingly well. Sway is virtually non-existent. That will make me a happy camper!
I did some careful measuring and I should be able to mount my 32" LG in the space. I have a tilting bracket and IF I tilt it just a bit, I believe that I can open the doors with the TV in place. I'm going to mount the bracket this weekend and give a try. If it does not work, I have a 24" that I know will fit. I just want the 32" LOL. We'll see.
