Bedlam
Sep 18, 2013Moderator
Standard garage door height openings are 7' high. Whether your actual garage door clears that 7' opening is dependent on the installer/installation. The cab of a 4x4 F-250 with 33" tall tires will clear under 7', but the antenna does not. My extended cab short bed is right around 19' long and a standard cab long bed is about 1/2' shorter. A crew cab long bed is close to 22' long. The F-350 is about 2" taller due to the rear axle blocks.
44,056 PostsLatest Activity: Jan 12, 2020
