anaro
Aug 17, 2014Explorer
Yup you have learned your weakness as many of us did the hard way. Working the math backward from the 515 lbs of available payload looks like a max trailer gvwr of 3400 lbs. If you can try upgrading your tv to a used more capable tv then you can get a larger trailer. Not sure how many are in your family. A 3/4 ton crew cab pickup will get you a whole lot of tt and can readily be found used. If you need more seating then you are limited to looking for a 3/4 ton suv (still not a lot of payload) or look for a large can ie ford E350. An suv that is well loved but very hard to find is the 3/4 ton ford excursion. They quit making these in 2005. Good luck. I feel for You, from a former limited payload Suv owner.
44,056 PostsLatest Activity: Nov 19, 2013
