nuckfanExplorerMay 29, 2015twisting jacksDoes anyone else have this issue? When raising or lowering the TC, only one of my front jack brackets pull away from the camper a little bit at the base of the plate and bottom lag bolt, then when res...Show More
tuna_fisherExplorerMay 29, 2015If you jack it out of level to much that will happen, not good. Try to jack evenly as not to put to much stress on front or rear jacks.
Related ContentTwisted Receiver SquareTwisted Truck? UPDATE-Fixed!ProPride WD Jack twists when raisedNewbie's Project: 2010 Tango Twist 21ftJack
