- AtleeExplorer IIFor Westcoasting, I'd say the 2 6V batteries are best. He is not using an inverter to power a TV or what not.
For the same reason, I'm getting a pair of 6V GC batteries. I want to run the water pump when necessary, run the furnace when necessary, run the lights when necessary, and run my CPAP machine when necessary. When necessary means when I do not have my generator(s) deployed. That 220 AH should tie me over for the night.
I have no intention of every adding an inverter.SoundGuy wrote:
Boon Docker wrote:
^ Two GC-2 (6v) batterys connected in series. Best bet for boon docking (dry camping).
The "best" batteries for camping without shore power are those capable of providing sufficient reserve for your intended draw down, those which are suitable for mounting in the space you have available, those which you can properly recharge, those which you can afford, and as discussed in this thread - for those who ever expect to use an inverter to power significant loads, batteries which can sustain that load without excessive voltage drop. ;) This is a far cry from simply saying GC-2s. :R - SoundGuyExplorer
Boon Docker wrote:
Exactly, 2 GC-2 (6v). :B
Well since you've posted this on the internet it must be true. :S - crosscheckExplorer II
And I'll raise you 2 GC-2's(6V).
Dave - Boon_DockerExplorer IIIExactly, 2 GC-2 (6v). :B
- SoundGuyExplorer
The "best" batteries for camping without shore power are those capable of providing sufficient reserve for your intended draw down, those which are suitable for mounting in the space you have available, those which you can properly recharge, those which you can afford, and as discussed in this thread - for those who ever expect to use an inverter to power significant loads, batteries which can sustain that load without excessive voltage drop. ;) This is a far cry from simply saying GC-2s. :R - Boon_DockerExplorer III^ Two GC-2 (6v) batterys connected in series. Best bet for boon docking (dry camping).
- WestcoastingExplorer
SoundGuy wrote:
SoundGuy wrote:
.. replaced my two paralleled group 27 batteries with a pair of golf cart batteries. I immediately noticed several differences. One, anytime I operated a heavy lo:Rad the voltage sagged MUCH more than it did with the old batteries.2oldman wrote:
For heavier draws, 4 or 6 batteries are much better.
Isn't that self evident? :R The fact remains that whether one uses six 6 volt GC-2s wired in series / parallel or three 12 volt G31s wired in parallel voltage drop under heavy inverter load will be less with the 12 volts than with the 6 volts. The second fact is that by using GC-2s which were specifically designed for golf cart use one is adapting batteries to RV use ... adapting, not using a battery specifically designed for the task at hand. ;)
What about dry camping for four days... only battery use is lights at night, and the water pump. Do you think two 12v for this application as well? What do you recommend for the best battery to buy? - SoundGuyExplorer
Isn't that self evident? :R The fact remains that whether one uses six 6 volt GC-2s wired in series / parallel or three 12 volt G31s wired in parallel voltage drop under heavy inverter load will be less with the 12 volts than with the 6 volts. The second fact is that by using GC-2s which were specifically designed for golf cart use one is adapting batteries to RV use ... adapting, not using a battery specifically designed for the task at hand. ;) - 2oldmanExplorer II
.. replaced my two paralleled group 27 batteries with a pair of golf cart batteries. I immediately noticed several differences. One, anytime I operated a heavy load the voltage sagged MUCH more than it did with the old batteries. - ktmrfsExplorer II
SoundGuy wrote:
lawrosa wrote:
Good read
http://yarchive.net/car/rv/golf_cart_batteries.html
http://yarchive.net/car/rv/battery_resistance.html
My comments are exactly the same as I posted in your own concurrent thread on this same topic, as follows.
More than a "good read", rather both are great articles from someone who understands much more than the masses here on this forum about the intricacies of deep cycle battery use for RVs, and which is summarized nicely in this statement which I've copied because most won't want to read through either of these links in their entirety. It sums up what a few of us have been trying to explain anytime this subject comes up - why 12 volt jugs in parallel are often the better choice than 6 volt jugs in series for RV use.
"Brian, if you have any large 12 volt loads such as an inverter I predict you will be disappointed with the golf cart batteries. I'll explain.
Two years ago I accepted the advice here in this group without thinking too much about it and replaced my two paralleled group 27 batteries with a pair of golf cart batteries. I immediately noticed several differences. One, anytime I operated a heavy load the voltage sagged MUCH more than it did with the old batteries. My inverter would trip off long before the batteries were discharged because of this. I'm speaking of terminal voltage and not at the other end of a length of wire. I could no longer fast charge them. The internal impedance was so high that they simply would not accept a fast charge without heating. My cordless battery charger could charge the old pair in an hour. It took several hours with the new one. Cranking the genny would drop the voltage so much that the inverter would trip. I got in the habit of hitting the interconnect switch before cranking so that the start battery could do the job.
I did some research like I should have done in the beginning. I learned that golf cart batteries are optimized for long, moderate rate discharges and are NOT designed for heavy loads. This is a mis application. In RVs that don't have heavy loads and don't need to fast charge it is not a problem."
And this has been just my point anytime this discussion comes up - adapting deep cycle 6 volt batteries that were originally designed for moderate, intermittent long term draw in golf carts is not the best choice when one of the main tasks of those batteries in an RV application is to supply power for short duration, heavy load inverter draws. These 2 articles you've linked to are the best I've seen that explains this in terms that are easy to understand, even for the "6 volt or go home crowd". :R
agree completely. I've advised many friends to NOT use a GC when they don't dry camp much and like to run microwaves, toaster etc. on the inverter. Each battery type has advantages and disadvantages. I think some people are oblivious to the disadvantage of a GC. At many RV shows, I've talked to Trojan reps about batteries. Just a "what battery should I use" and EVERY time the first question is "do you like to run a microwave, or electric tea pot etc." then followed by some other use questions. In every case they have said if high current draw is important, then use a 12V deep discharge battery NOT a GC.
44,025 PostsLatest Activity: Feb 18, 2025
