newtondak
Jun 09, 2013Explorer
Two wheel drive or 4x4?
Looking at purchasing a new tow vehicle and considering the pros and cons of two wheel vs four wheel drive. Which do you have and why did you make that choice?
The Mad Norsky wrote:Ezbagr wrote:
One other thing, a 4X4 is going to cost more for front end maintanence and so on.
Again, as I said previously in the thread, false.
Mind you, if you treat your pickup like a Jeep, then yes, I could agree with the above.
But tearing things up for fun has never been a priority of mine.
Said earlier I've had nine four wheel drives during my lifetime. The only one I recall ever doing any front maintenance on was my 1977 Ford F-250, and it was hub bearing problems, warrantied by Ford. Fact is, that was only once, and after being changed out, never another problem with that truck.
I really believe that you are the exception. If one keeps a four wheel drive for 150,000 miles or more there is going to be a time when front end work-hubs,bearings and ball joints will need to be worked on and it will cost considerably more to have this work performed on a 4X4 compared to a 2 wheel drive.
No u-joints, no hubs (just above) no broken drive lines. No maintenance needed, save for my own greasing of u-joints at the time when they did put zerks on them.
No transfer case problems.
Perhaps my care is the exception, I do not know.
But I have found you take care of the truck, for the most part it takes care of you.
