Slownsy
May 03, 2016Explorer
Tyre pressures
Weight of ouer F350 single rear tyers 1680lb front 2350lb. Tyers Michelin LTX A/T 275/65 R20 rated at 3750lb at 80 psi. Ford recommends 65lb front 80lb rear. According to michelins load and inflation ...
Slownsy wrote:
Weight of ouer F350 single rear tyers 1680lb front 2350lb. Tyers Michelin LTX A/T 275/65 R20 rated at 3750lb at 80 psi. Ford recommends 65lb front 80lb rear. According to michelins load and inflation tables I se 2080lb at 35 psi and 2475lb at 45psi.
What are others using and how low would you go.
Frank.
