Hemling
Jul 27, 2021Explorer
Ultimate payload monster?
What do you think is the top payload rating among new one-ton trucks? All the advertising goes toward horsepower/torque and towing capacity, but what configuration is king of payload?
JRscooby wrote:
I understand what you are saying. I have owned and worked trucks most of my life. But I have only bought 2 half ton pickups and 1 F 350 new. (And the 350 was at a real deep discount because the paint was damaged when the dealership burned)
I bought 3 Macks for a job. 16&44s, GVWR 50. But all hauling was off-road, or on closed hiways. I licensed them 24,000, and if they had to be moved, drove myself, because the "drivers" I put in them did not have CDL. (They made good money for part time work) But no matter what plate I put on them, the GVWR did not change.
At the same time I was running 3 Fords, where I had bought single axle tractors, changed front axles, cut and spliced the frames to make long enough for bed, and 44,000 rears. I used cab and engine from the newer trucks, but can not change the 80,000 GCVWR on ID plate. But I was still legal, and the state weight watcher would not even pull out the scales when GCVWR was around 110,000
