Hemling
Jul 28, 2021Explorer
Ultimate payload monster?
What do you think is the top payload rating among new one-ton trucks? All the advertising goes toward horsepower/torque and towing capacity, but what configuration is king of payload?
Cummins12V98 wrote:
"Trucks have outgrown these classifications and limitations yet the manufacturers ratings are restricted by them regardless if the trucks can actually carry more weight."
EXACTLY!!!
Cummins12V98 wrote:
"Cummins12V98 wrote:
No one is going to respond directly to my question of how my SAE rear axle rating plus unloaded front axle weight is 1.000# over my 14k GVWR???
JRscooby said.......Sorry, I kinda thought I did.
You did but didn't explain why.
Ron,
You make me laugh!
So our axles add up to 6,000 + 9,750 = 15,750# axle capacity to a 14,000# GVWR is 12.5% more axle capacity than GVWR.
Now go back to your Gen 2 Ram 5,200 + 6,084 = 11,284# axle capacity to a 8,800# GVWR or 28.2% more axle capacity than GVWR.
So less cushion on the new truck than the old.:B
noteven wrote:
Gas engine
Standard Cab & chassis with Aluma flatbed
Smallest fuel tank
2wd
Rear dools
rjstractor wrote:JRScooby wrote:
I ain't much smarter than a box of rocks, but I would guess there might be other components that limit GWR?
BTW, I don't think I have ever seen a weight tag where the total of axle weights is not greater than GVWR.
On a pickup you won't see that but on commercial trucks you likely will. My former motorhome, a 1998 E450 based C had a RGAWR of 9450 and a FGAWR of 4600 and a GVWR of..... 14050. Those axle weight ratings are lower than those of a 350/3500 series dually pickup yet the GVWR is just over 14K, probably to put it into the class 4 truck group and reduce the emission requirements. Fast forward to today. The new E450 has axles of 9600/5000 and a GVWR of 14500, again lower axle ratings than a new F450 dually, which can be as high as 9900/6000. Yet the GVWR of said truck is only 14000. If this isn't evidence of the OEMs artificially lowering GVWRs of pickup trucks to keep them in a given DOT weight class, I can't imagine what is. If Ford used the same criteria for the F450 pickup (not cab and chassis) as the E450 cutaway its GVWR would be 15,500 or more.
