azwildcat's avatar
azwildcat
Unable to shift out of Park
I have a 2019 F250 Super Duty, 4x2, 6.2 Gas, 6-Speed Trans. 5500 miles on it at the time of the problem. I started the engine and attempted to back up. The gear shift would not move out of park. The engine was running fine and the brake lights were working. Called Ford road side assistance for a tow to the dealer. Arrived at the dealer about 4:30 pm. They would look at it the next morning. Asked about a loaner--no luck. They have to diagnose the problem first. They kept the vehicle all the next day and their diagnose was a blown fuse. Unable to determine why the fuse blew. Replaced the fuse F9 (10 amp). The owners manual states that if you cannot move the gearshift out of park and the brake pedal is pressed and the brake lights are working you may have a "malfunction". Has anyone else had a similar problem or have any idea what really caused the problem. I did purchase a couple of extra fuses ($6.41 each) as a precaution if it happens again. 1500 miles later everything seems to be fine.
  • bguy wrote:
    There should be a transmission shift interlock override. I'm sure it's outlined in the OM.
    No - What the OM says is to check the fuse.
  • There should be a transmission shift interlock override. I'm sure it's outlined in the OM.
  • Thanks for sharing. I will let my father-in-law know that he should carry a few extra fuses just in case.
