SDcampowneroper
Mar 30, 2018Explorer
Blowing out or A/F is a matter of being very thorough, going tap to faucet to toilet to shower several times. Shower heads and aerators removed. Think it through do not miss anything including blowing out the black tank rinser. You cant AF that.
Pump a little pink through the pump, but not through the fresh tank, do it with the bypass valve if you have one, if not disconnect the intake from the tank to the pump screw on a short hose to the pump to insert into the af jug. When done this way until the pipes blow dust it has worked for us and guests. In either case you must think of all piping.
Another thing, We winterize piping on 84 campsites, 12 buildings , 2 pools, About 30 rvs every year one at a time but it takes 3 30 gallon compressors hours to dry a 3/4 mile of pipe to blow the campsites.the only AF used is in drains and toilets.
pink is better if you do not have a high volume air compressor. Job site compressors are generally to small
