firemedic1169's avatar
Jul 01, 2013
Underbelly removal help needed.
I have a 2008 Springdale 267BH. I have developed a leak which I believe is coming from the waterlines under the floor. I crawled underneath and there is no obvious way to remove the underbelly. I'm inclined to just just cut it and figure out how to patch later as its going to take 4 weeks to get my camper into the nearest service center and I have multiple trips scheduled and need to fix this ASAP. Does anyone have any experience and advise on this?
  • It is the black mesh type. It seems to be glued or other wise attached to the top of the metal cross-members or maybe even sandwiched between the metal cross-members and something above. either way it does'nt appear to be as simpe as unscrewing or unbolting
  • Does yours have the corrugated plastic or the mesh type material? Either way, you can cut it.
    If you have the mesh like material, I would go back with the corrugated plastic (the stuff they use for signs)and you can get it in 4x8 sheets. It is simply screwed to the frame with big flat washers and self tapping screws.
