Mikesr's avatar
Mikesr
Underbelly repair tape
Can anyone recommend a good underbelly repair tape? I looked on Amazon and I'am seeing mixed reviews on different products. Looks like most are 4 inch wide but wider would be better. I need to seal up some sagging underbelly material around the dump valves. Also looking for. Good RV quality expansion foam for underbelly too.
Thanks
  • richk88 wrote:
    not cheap, but good stuff underbelly tape
    Thanks
    Have you used this stuff? I want something that will last. My dealer did a crappy repair with a cheap tape and I want to redue it before it gets worse.
    Thanks
  • I used black Gorilla tape to seal the bottom after I cut it open to fix a gate valve. Gorilla tape will stick to everything. I use Great Stuff to seal the holes.
