coolmom42 wrote:
It means you have transferred a total of 465 lb of trailer weight to the truck, and it seems to be 200 lb on the rear axle and 265 on the front. You've added more weight to the front axle than the rear, which might make the rear end squirrely. Seems you need to back off the WD just a little bit.
Other issue: Looks like 465 lb is the tongue weight of the trailer. Is that 10-15 percent of the trailer gross? If not, the trailer is too light on the tongue. you can get the trailer gross using RCMAN46's second weight total minus the third weight total.
Another issue: is the trailer level or slightly tongue down when connected.
deleted (I wish I knew how to actually delete a post).
