bguy
Feb 10, 2014Explorer
jbres wrote:
I just got underneath the Tahoe again. On the front driveshaft where the front universal is I CANNOT rattle it back it forth side to side. BUT on the front driveshaft rear universal I can rattle the universal joint up and down and side to side. Its got a pretty good amount of wobble to it. Even though this is my front driveshaft and not my rear, could this be the clunking I am hearing?
You don't have full time 4wd, so unless you're running around in 4 all the time you can forget the front driveshaft. If you're at all mechanically inclined remove the rear shaft and inspect the joints. Descriptions given don't make me think U-joints. U-joints will usually produce a "shaking" while you're bootin down the road or under acceleration.
44,072 PostsLatest Activity: Aug 23, 2026
