Flyfisherman128
Feb 10, 2014Explorer
If in doubt take them out.. If you know what you are doing, changing the u-joints cant take half hour per drive shaft, an hour if you don't know what your doing and set you back about $20 per set. Personally I would change them out because its the easiest and cheapest thing to do. Like others have said, put in the greasable ones. A little trick, put a couple of clamps on the bearing caps and pump grease before you install them.. save you lots of aggravation.
44,072 PostsLatest Activity: Aug 23, 2026
