Artum_Snowbird
Oct 25, 2017Explorer
You have probably noticed that one of the back jacks will come off the ground when you jack. It is possible to jack up with two front jacks and only one on the back. Remove the bent one, and put one from the back onto that spot.
Move weighty things inside off that side of the camper that will have no jack, and you will be fine.
When I bent mine I tried with a welder to straighten it, but it never worked so I had to discard it. Of course, you buy the motor separate from the jack, so replace the jack only, not the motor part.
44,071 PostsLatest Activity: Sep 17, 2026
