Prior_Pete's avatar
Prior_Pete
Upgrade WD Bars?
Bought a new, heavier trailer last year & upgraded my Reese Dual Cam WD bars from 800 to 1,000lbs. Trailer weighs about 8,200 lbs & tongue weight is just over 950lbs. Any harm in going to 1,200lb bars or is that what I should be using anyways? Right now the trailer tows beautifully but I was thinking there would be no harm in getting stronger bars. Also wondering if the bars are different lengths depending on rating. Thanks for any & all help.
  • I would use what you have, designed for the load you have. Stiffer bars does not necessarily mean better.
  • The main difference in the size of spring bars is its relative stiffness. The overall dimensions (the ones that count) will be the same. I have found that going with a rating too much over your tongue weight will make the ride less progressive and twitchy near the limit. I tried this with my old TT to see what the difference was I went back down to the 1,000lb bars after a few trips.
    Remember, the bar's main function is leverage weight towards the front truck axle and collaterally the trailer's tandem axles. A stiffer bar will give less and transfer that weight during bumps and dips faster and more harshly than a lighter weight bar.
    You can also expect greater wear to the points of connection as more strain is added to them with each bump. Not that it is much more wear. I did notice more metal dust at the end of the few rides I did take with the 1,200lb bars.
    All that said, that was just my experience. Other than the cost of the new bars, there shouldn't be any harm in trying them.
  • If the 1000# bars work Id just use them or call Reese and see what they'd recommend.
  • Well, I've been using #1000 bars for a #650 TW trailer for 15 years and it's all been good for me..
    I think that using #1200 bars for #950 TW would be just fine..
    Good luck!
    Mitch
