Twistedlarch's avatar
Twistedlarch
Upgraded my tow vehicle, do I still need a WDH?
Hi all, I just upgraded from a Tacoma to a Tundra. My 21' TT weighs in at 3,725 lbs with a tongue weight of 410 lbs. It squatted my Tacoma pretty good but doesn't seem to phase the Tundra much.
My question is...Do I still need to use the weight distribution hitch?
I found a standard stinger that will also support the anti-sway system and the Tundra has the integrated brake controller with anti-sway built in, will this work or should I still use the WDH?
Thanks!
Brian
  • Ivylog's avatar
    Ivylog
    Explorer III
    For 500lbs if tongue weight I would NOT use WD.
  • The hitch is for the trailer, not the truck. takes the sway out.
  • If you are under the "weight carrying" tongue weight rating on your hitch receiver, I'd skip it on your setup. But it probably requires WD over 500 pounds, and I suspect you actual tongue weight is above that.
  • I don't know. But if you think of it like this, you might draw a different conclusion:
    (Edited)...
    Thanks!
    Brian
    Are those actual scaled weights loaded for a trip that you had done? Or the advertised brochure weights?
    Those are the advertised weights. The scaled weight connected to the truck is 3343 and just a hair over 3,800 disconnected. For our big trip next Summer I imagine these weights will go up some.
    Thanks!
    Brian
  • The purpose of a WDH is to distribute some of the hitch weight to the front wheels of the truck and is not for leveling the truck. It is a bit safer to use the WDH. The anti-sway in the truck will do nothing to prevent a trailer from swaying.
