FastEagle
Nov 18, 2014Explorer
path1 wrote:BurbMan wrote:
Pth, crawl under the TT and there will be a sticker on the axle tube with the rating and specs on it. Axle rating is for the axle, so a 6000 lb axle can carry 600 lbs, 3000 on each wheel/tire. If you install tires rated at 2000 lbs each, you effectively have a 4000 lb axle rating.
Thanks, will look for sticker
You should be looking for the GAWR on the certification label. Tires are fitted to the GAWR NOT the axle rating unless the GAWR and axles have the same load capacity.
FastEagle
